95 Civic DX temp & fuel gauges problem
Old Jul 12, 2010 | 01:31 PM
nyioo7's Avatar
nyioo7
Default 95 Civic DX temp & fuel gauges problem
Hi. I have a problem with my car's temperature and fuel gauges. My car is 95 Civic DX with D16Y8 engine. What happened was, I pulled out the gauge cluster to fix the erratic speedometer gauge. When I put the cluster back in, and turn the car on without starting engine, my temperature and fuel gauges started going up all the way to max. I tried to tighten and loosen the sensor screws in the back and still didn't change anything. When I take out the sensor screws gauges stopped working. I'm assuming, sensors are working fine but something happened to gauges. Anyone familier with this kind of problem? Please help.
P.S. My speedometer is fine now. The sensor screw on the back was loose.
Old Jul 14, 2010 | 09:45 PM
nyioo7's Avatar
nyioo7
This is quite hopeless.
Old Jul 21, 2010 | 07:02 PM
Omie's Avatar
Omie
ew n!gg@ u g@y
see if anyone you know that has a civic 92-95 and swap clusters see if that fixes your problem or happens to there cars as well
Old Jul 31, 2010 | 06:15 PM
A-series's Avatar
A-series
v-card member alpha
Same thing happened to my fuel gauge (but luckily not the temp. gauge). I took out the cluster to fix my erratic/occasionally jumping tachometer (the screws holding it in place were loose) and while it was out I carefully moved all the needles to make sure they moved smoothly. Unfortunately I moved the fuel gauge needle just a bit too far, too close to the full mark and that can apparently ruin the fuel or temp. gauges. It says in the service manual that if you are checking the electrical connection at the fuel pump or at the temp. sensor that you have to stop shorting it (to make the needle move) before it reaches the full mark or it will damage the gauge. I was aware of that but didn't realize it would also apply to moving it by hand...
The tach. and speedo. needles can be moved by hand to check for binding [and I believe this applies to all the gauges on newer models (honda/acura at least), even the temp. and fuel. I believe for Civics it's the '01+ that don't have that quirk anymore] - although they shouldn't bind unless someone has messed with the cluster previously - but the fuel and temp. pod of all older Hondas/Acuras (and I'm sure many other makes) should be left alone when the cluster is being worked on as they're obviously very finicky.
edit: you'll need a new temp/fuel pod to fix it, and unfortunately those usually aren't sold separately that I've seen. I'm talking about ebay of course. Even then you can't be totally sure those temp/fuel gauges will work b/c people have reported that as an issue with used clusters off of ebay.
If you have a salvage yard close by that has your type of cluster you might be in luck.
