Automotive News & Rumors Highlighting the latest in what's happening in and around the automotive industry.
2011 Honda CR-Z Specifications and Features
Old Jun 18, 2010 | 11:00 AM
94civicEX's Avatar
94civicEX
I got worms.
Default 2011 Honda CR-Z Specifications and Features
Torrance, Calif. - Jun 18 — ENGINEERING CR-Z CR-Z EX Engine Type In-Line 4-Cylinder In-Line 4-Cylinder Engine Block/Cylinder Head Aluminum-Alloy Aluminum-Alloy Displacement (L/cc) 1.5 /1497 1.5 /1497 Horsepower @ rpm (SAE net) 122 @ 6000 122 @ 6000 Torque (lb-ft @ rpm) 122 @ 1000 - 1750 (6MT)
123@ 1000 - 2000 (CVT) 122 @ 1000 - 1750 (6MT)
123@ 1000 - 2000 (CVT) Redline (rpm) 6300 6300 Bore and Stroke (mm) 73 x 89 73 x 89 Compression Ratio 10.4 : 1 10.4 : 1 Valve Train 16-Valve SOHC i-VTEC® 16-Valve SOHC i-VTEC® Multi-Point Fuel Injection ? ? Drive-by-Wire? Throttle System ? ? Hill Start Assist 6MT 6MT Front-Wheel Drive ? ? 3-Mode Drive System (Sport/Normal/ECON) • • Eco Assist™ System • • CARB Emissions Rating AT-PZEV** AT-PZEV** Federal Emissions Rating Tier 2 Bin 2 Tier 2 Bin 2 Direct Ignition System with Immobilizer ? ? 100K +/- Miles No Scheduled Tune-Ups* ? ? * Does not apply to fluid and filter changes. Will vary with driving conditions. Please see your Honda dealer for details. ** AT-PZEV (Advanced Technology Partial Zero-Emission Vehicle) models as certified by California Air Resources Board (CARB) are available in California and states that have adopted California Zero-Emission Vehicle regulations. ELECTRIC MOTOR / GENERATOR CR-Z CR-Z EX DC Brushless Motor (Permanent Magnet AC Synchronous) • • Power (hp @ rpm) 13 @ 1500 13 @ 1500 Torque (lb-ft @ rpm) 58 @ 1000 58 @ 1000 ELECTRIC POWER STORAGE CR-Z CR-Z EX Nickel Metal Hydride (Ni-MH) Battery • • Output (Volts) 100.8 100.8 Rated Capacity 5.75 Ah 5.75 Ah TRANSMISSIONS CR-Z CR-Z EX 6-Speed Manual Transmission ? ? Gear Ratios: 1st: 3.143, 2nd: 1.870, 3rd: 1.303, 4th: 1.054, 5th: 0.854, 6th: 0.689, Reverse: 3.307, Final Drive: 4.11 Continuously Variable Transmission (CVT) with Paddle Shifter with Paddle Shifter Gear Ratios: 3.173~0.529, Reverse: 5.666~2.167, Final Drive: 4.20 BODY/SUSPENSION/CHASSIS CR-Z CR-Z EX Unit-Body Construction ? ? MacPherson Strut Front Suspension ? ? Torsion-Beam Rear Suspension ? ? Stabilizer Bar (mm, front/rear) 18.0 (solid) / 18.0 18.0 (solid) / 18.0 Electric Power-Assisted Rack-and-Pinion Steering (EPS) ? ? Steering Wheel Turns, Lock-to-Lock 2.48 2.48 Steering Ratio 12.75 12.75 Turning Diameter, Curb-to-Curb (ft) 35.4 35.4 Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in, front/rear) 10.3 / 10.2 10.3 / 10.2 Alloy Wheels (inches) 16 x 6 16 x 6 All-Season Tires P195/55R16 86V P195/55R16 86V Compact Spare Tire ? ? EXTERIOR MEASUREMENTS CR-Z CR-Z EX Wheelbase (in) 95.9 95.9 Length (in) 160.6 160.6 Height (in)* 54.9 54.9 Width (in) 68.5 68.5 Track (in, front/rear) 59.6 / 59.1 59.6 / 59.1 Curb Weight (lbs, MT/CVT) 2637 / 2690 2650 / 2703
2654 / 2707 (EX w/Navigation) Weight Distribution (%, front/rear, MT) 58.8 / 41.2 58.8 / 41.2 Weight Distribution (%, front/rear, CVT) 59.8 / 40.2 59.8 / 40.2 *Height includes roof antenna INTERIOR MEASUREMENTS CR-Z CR-Z EX Headroom (in) 36.9 36.9 Legroom (in) 42.7 42.7 Shoulder Room (in) 53.8 53.8 Hiproom (in) 51.5 51.5 Cargo Volume (cu ft, behind seats) TBD TBD Passenger Volume (cu ft) 49.1 49.1 Seating Capacity 2 2 EPA MILEAGE ESTIMATES*/CAPACITIES CR-Z CR-Z EX CVT (City/Highway/Combined) 35/39/37 35/39/37 6-Speed Manual (City/Highway/Combined) 31/37/34 31/37/34 Crankcase (qt) 4.2 4.2 Coolant System (qt, CVT/MT) 4.84 / 4.92 4.84 / 4.92 Fuel (gal) 10.6 10.6 Required Fuel Regular Unleaded Regular Unleaded * Based on 2011 EPA mileage estimates. Use for comparison purposes only. Do not compare to models before 2008. Your actual mileage will vary depending on how you drive and maintain your vehicle. SAFETY CR-Z CR-Z EX 3-Point Seat Belts with Front Seat Automatic Tensioning System ? ? Driver's and Front Passenger's Seat Belt Reminder ? ? Dual-Stage, Multiple-Threshold Front Airbags (SRS) ? ? Front Side Airbags with Passenger-Side Occupant Position Detection System (OPDS) ? ? Side Curtain Airbags ? ? Driver's and Front Passenger's Active Head Restraints ? ? Advanced Compatibility Engineering™ (ACE™) Body Structure ? ? Anti-Lock Braking System (ABS) ? ? Electronic Brake Distribution (EBD) ? ? Brake Assist • • Vehicle Stability Assist™ (VSA®) with Traction Control ? ? Tire Pressure Monitoring System (TPMS) ? ? Daytime Running Lights (DRL) ? ? Side-Impact Door Beams ? ? EXTERIOR FEATURES CR-Z CR-Z EX Fin-Type Roof-Mounted Antenna • • Security System with Remote Entry ? ? Body-Colored Folding Power Side Mirrors with Integrated Turn Indicators • Heated Body-Colored Door Handles ? • Projector-Beam Halogen Headlights with Auto-On/Off • High-Intensity Discharge (HID) Headlights with Auto-On/Off • Fog Lights ? Variable Intermittent Windshield Wipers • • Rear Window Wiper/Washer • • Tinted Glass • • Push-to-Release Fuel Filler Door • • LED Brakelights ? ? COMFORT & CONVENIENCE CR-Z CR-Z EX Automatic Climate Control • ? Honda Satellite-Linked Navigation System™ with Voice Recognition Available Bluetooth® HandsFreeLink® • Power Windows with Auto-Up/Down Driver's Window • ? Illuminated Window Switches Driver's window only ? Power Door Locks • • Cruise Control • ? Leather-Wrapped Steering Wheel • Aluminum Shift Knob with Leather 6MT Textured Aluminum Pedals • Polished Interior Accents • Steering Wheel-Mounted Paddle Shifters CVT CVT Tilt and Telescopic Steering Column ? ? Illuminated Steering Wheel-Mounted Controls Cruise/MID/Audio Cruise/MID/Audio/Phone Illuminated Steering Wheel-Mounted Navigation Controls Available Beverage Holders (3) ? ? Upper Instrument Panel Storage • • Door-Pocket Storage Bins, Front ? ? Driver's and Front Passenger's Vanity Mirrors Driver's only Illuminated Ambient Console Lighting ? Map Lights ? ? 12-Volt Power Outlet ? ? Glove Compartment ? ? Courtesy Lights • ? Rear Cargo Console (behind front seats) • • Rear Window Defroster ? ? Retractable Cargo Area Cover • ? Cargo Area Light ? ? SEATING CR-Z CR-Z EX Silver Mesh Sport Seats • • Driver's Seat with Manual Height Adjustment ? ? Reclining Front Seatbacks ? ? AUDIO SYSTEMS CR-Z CR-Z EX 160-Watt AM/FM/CD Audio System with 6 Speakers • 360-Watt AM/FM//CD Premium Audio System with 7 Speakers including Subwoofer • Radio Data System (RDS) • without Navigation MP3/Windows Media® Audio (WMA) Playback Capability • ? MP3/Auxiliary Input Jack • ? USB Audio Interface • • CD Text Display Capability • ? Digital Audio-Card Reader with Navigation Speed-Sensitive Volume Control (SVC) • ? INSTRUMENTATION CR-Z CR-Z EX 3-Mode Drive System Buttons (Normal / ECON / Sport) ? ? 12-Volt Battery Charging System Indicator ? ? ABS Indicator ? ? Airbag System Indicator ? ? Blue Backlit Gauges • • Brake System Indicator ? ? Coolant Temperature Indicators ? ? Cruise Control Indicators • • Digital Speedometer • • Door/Hatch-Open Indicator • • DRL Indicator • • Electric Power Steering (EPS) Indicator ? ? Fog Light Indicator ? Fuel Level Indicator ? ? Headlight-On Indicator • • High-Beam Indicator ? ? Idle-Stop Indicator ? ? IMA Battery State-of-Charge Indicator • • IMA Charge and Assist Indicator • • IMA System Indicator • • Immobilizer System Indicator • • Lights-On Indicator • • Low Tire-Pressure Indicator • • Low-Fuel Indicator • • Low-Oil Pressure Indicator • • Maintenance Minder Indicator • • Malfunction Indicator • • Passenger-Side Side Airbag-Off Indicator • • Seat Belt Reminder Indicator • • Security System Indicator • • Shift Up/Down Indicator 6MT 6MT Tachometer • • TPMS Indicator • • Turn Signal/Hazard Indicators • • VSA System and Off Indicators • Multi-Information Display (MID) CR-Z CR-Z EX Average Fuel Economy Indicators (2) • • Average Speed Indicator • • Bluetooth® HandsFreeLink® • Digital Fuel-Mileage Indicators • • Digital Odometer and Digital Trip Meters • • Eco Guide/Eco Score • • Elapsed Time Indicator • • Exterior Temperature Indicator • • IMA System Power Flow Indicator • • Maintenance Minder™ System • • Miles-to-Empty Indicator • • Exterior Accessories Interior Accessories 17x7-inch Alloy Wheel XM Radio P205/45R17 84V Performance Tires Armrest with Storage Front Lip Spoiler Stainless Steel Door Sill Trim Body Side Molding Illuminated Door Sill Trim Side Spoiler Auto Day/Night Mirror with Compass Rear Diffuser Spoiler Ashtray, Cup Holder Type Hatch Spoiler All-Season Floor Mats Splash Guards Cargo Mat Wheel Locks Cargo Tray Fog Lights (CR-Z base trim only) Engine Block Heater Full Nose Mask Door Edge Film Rear Bumper Applique Car Cover Specifications, features, illustrations and equipment shown in this press kit are based upon the latest available information at the time of printing. Although descriptions are believed to be correct, accuracy cannot be guaranteed.
More...
