resistors for LEDs question
Old Apr 2, 2003 | 12:14 PM
RY2K's Avatar
RY2K
5 speed
Default resistors for LEDs question
i have previosly played around with a couple of LEDs from radio shack and the bulbs are 3.7volts min and 4.5 volts max and i did the equation that Illusion had on his website:thumbup:, and he recomended 470-Ohm resistors and i got the ½ watt ones and used them and they came out fine
i went to radio shack yesterday and i saw that they had 470-Ohm ¼ watt ones so i picked up both
so my question is do i use the ¼ watt ones or the ½ watt ones
Thank you,
RY2K
here is a picture, it's hard to read so i drew on the pic
i want to do this the correct way, and not mess up my car so i apreciate any input
Old Apr 2, 2003 | 04:41 PM
Bl@ck's Avatar
Bl@ck
Sinner
wattage is a measurement of power. the wattage rating on a resistor is basically how many watts/milliwats it can safely dissipate as heat. i'd go with the 1/2 watt ones. better to be safe than sorry.
Old Apr 2, 2003 | 05:47 PM
luti's Avatar
luti
Whats the equation you used to figure this out?
Old Apr 2, 2003 | 08:13 PM
JERZY-STYLZ's Avatar
JERZY-STYLZ
I usually use 220 ohm.....but da jus me.
If anything is to get screwed up by using the wrong resistor, it would be the LED itself and nothing else....feel free to correct me if im wrong
Old Apr 2, 2003 | 11:23 PM
Bl@ck's Avatar
Bl@ck
Sinner
Ohm's law E=I/R :dunno:
Old Apr 3, 2003 | 12:20 AM
RY2K's Avatar
RY2K
5 speed
ok so i'll use the 1/2 watt, i didn't know about the heat
what is the voltage of the LED you use the 220 ohm resistor with, and does it make it brighter
thats good to know cause my friend got me worried, i hope you're correct:happysad:
E = I*R so R = E/I
check out the web page it's explained really well
http://www.igd4u.com/modules.php?op=...=article&sid=2
Old Apr 3, 2003 | 07:58 AM
Bl@ck's Avatar
Bl@ck
Sinner
Originally posted by RY2K
E = I*R so R = E/I
:doh: i knew that.... it's been a while since i used it though
here's the extended equation to calculate power in a circuit.
using W=E^2/R you'll see that the 1/4 watt resistors won't cut it. and a burning resistor don't smell good at all.
Old Apr 3, 2003 | 10:47 AM
RY2K's Avatar
RY2K
5 speed
thanks for the equation picture
my car smells like cucumber melon, and a burnt resistor would not be very :grinpimp:
Old Apr 3, 2003 | 01:41 PM
Bl@ck's Avatar
Bl@ck
Sinner
yeah, that ish smells like ass... i used to burn one every morning in electronics class in high school just to be an asshole:thumbup:
Old Apr 29, 2003 | 05:17 PM
digitech's Avatar
digitech
I go with the 220 ohms with the 3.5v. It's the best combo 4 leds and resistors.
