Tach on a VX cluster
Old Apr 1, 2003 | 09:00 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Default Tach on a VX cluster
is it possible to just get aftermarket cluster face like for an ex and put it onto a VX Tach or will it not work? The reasing being is that the red line on the VX is 6k-8k where as the EX is 7.2k-9k. thanks
Patrick
Old Apr 1, 2003 | 09:05 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
i dont think it will work,..this is why i think it will not work,... the needle will say your at 3 grand but really your not
Old Apr 1, 2003 | 10:53 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
i've always thought that it would work, but i guess i don't know for absolute sure.
Old Apr 2, 2003 | 04:51 AM
Paul's Avatar
Paul
Eater of Rice
why don't you just get the tach from an ex and swap it out with your vx.
Old Apr 2, 2003 | 09:11 AM
flipped cracka
oh, that's what i was thinking they were talking about. it would make more sense.
Old Apr 2, 2003 | 10:12 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
i believe the numbers on the gauage are the same, just the redline is moved. you should shift for your engin, not the redline anyway, but if it bothers you, then get an aftermarket faceplate for the junkyard cluster.
i changed my cluster out with the correct mileage in well under an hour...but it was an LX cluster into a DX so i think the lines are where they should be.
Old Apr 2, 2003 | 10:25 AM
HatchVX's Avatar
HatchVX
the problem is that i have to find another EX or LX cluster to swap it out with. My freind was talking about buying. If that coudl work then i would tell him. Thanks
Old Apr 2, 2003 | 12:23 PM
Kai's Avatar
Kai
Rotorphile.
Do what? I thought you just put that EX cluster in your car?
That aside, look at the gauges. If the 1k, 2k, 3k, and 4k lines are at the same place, you can probably use new faces to hide the fact that one is a VX cluster and still be properly calibrated. If the numbers are in different places around the arc of needle movement, you're outta luck.
Old Apr 2, 2003 | 12:51 PM
Fujiwara Takumi
It's my first day.
i really doubt thats the case...that would mean that the tach, sensor, and whatever other electronics is different for every car they build...my guess is they are all the same k marks with different red lines.
Old Apr 2, 2003 | 12:53 PM
Kai's Avatar
Kai
Rotorphile.
You're probably right. I'll look into it this weekend, if hatch doesn't figure it out before then.
