How much vacuum at idle???
Old Jun 27, 2002 | 07:10 AM
Sickboy's Avatar
Sickboy
Default How much vacuum at idle???
I am having a problem with my engine not running right, it runs rich all the time, except when the car is decelerating. I think it might be a vacuum leak, but I'm not sure what exactly the vacuum is supposed to be at. I know mine is reading about 18 at idle, and if you give it gas it goes down of course. Is there a good way to test for leaks? If not a vacuum leak, then what else could cause it to run rich all the time?
Rob
Old Jun 27, 2002 | 08:28 AM
jdblack1's Avatar
jdblack1
You should be getting around 22-25 vacuum. When you blip the throttle it should go up to 0. At WOT it should also be 0
Old Jun 28, 2002 | 11:21 AM
AP2's Avatar
AP2
Moderator Alumni
18-21 in at idle is fine. And when you let off while cruising, it's normal for the vaccum to dip to 25 in.
Old Jul 7, 2002 | 11:01 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
22in/Hg or ~560mm/Hg
Toy Civic
4
Mar 14, 2007 09:11 AM
Chris N
13
Mar 29, 2004 11:38 AM
miguel6632
92+ Civic/EL & Del Sol
8
Mar 12, 2004 06:10 PM
menappi
CRX & Pre 92 Civic
Oct 31, 2003 12:35 PM
N2civicsi
Engine Swaps, Tech & Tuning
Mar 3, 2003 07:52 PM
