Type r tranny what axels??
what import tooner says.
i always say 94-95 ls with out abs. :dunno:
Does it make a difference or not if you get the one with abs or without abs. They look the same to me.
i heard it has different teeth on the axles where it meets the hub. Not exactly sure, but since they specify I chose a B series axle that would be found in a non abs car. :dunno:
I think its something else, cause I had to get some new axles, and the place only had one side, so I got me axles from 2 different places. When I looked at the boxes, one box said ABS, and the other box said non-abs.
Both fit perfectly in
Originally posted by skeeterDX
I got a 2000 civic HB dx will I need to change the hubs at all?
To run b - series axels?
You have 2 options.
You can run 90-93 integra axles and halfshaft
All the 94up B-series axles are the same, even the automatics. Just make sure you match up the axles with the correct intermediate shaft.
In fact, you can run any b-series passenger side axle from 90-01, they are all the same. It's the drivers side that is different.
I run a 99 b16a2 passenger side axle and a 93 GSR intermediate shaft and axle.
You can get any ABS or non-abs axle, too.
