Engineering statics help
Old Apr 23, 2010 | 11:07 AM
Line7's Avatar
Line7
Platinum Member
Default Engineering statics help
I am supposed to draw a shear force diagram of the loading shown. I used hypothetical number. This is what I did and for some reason its not coming out right.
The shear at the right hand side of the beam should be zero. Because the reaction is 3/2 kips upward and the shearing due to the distributed load is -2 and 3/2 right before you account the upward right-most reaction, it does not go to zero. Please check this for me and tell me where I went wrong. Thganks
EDIT: the length of the entire beam is 2ft. and the 1 kip load is at midspan. I calculated the reactions here. I figured they are equal due to symmetry.
Old Apr 23, 2010 | 02:29 PM
Red X's Avatar
Red X
x pǝɹ
I can help you but I need you to explain the problem better. What is it that you expect (the solution) and what are you getting?
Old Apr 23, 2010 | 02:33 PM
Old Apr 23, 2010 | 06:52 PM
azn_redneck's Avatar
azn_redneck
Live Free Or Die
Haven't had to do a shear diagram since sophomore year in college - 14 years ago.
It looks like it should be +3/2 at the start, -1/2 at midspan, and -3/2 at the end. With an end reaction of +3/2, the -3/2 from the load should cancel out. I think.
