Smog Help
Old Apr 22, 2010 | 12:20 PM
Love2RedLine's Avatar
Love2RedLine
My 4th Acura
Default Smog Help
I have a swap in my GSR and I can not get it to pass smog. Is there anyone on here that can help me out with this?
Old Apr 22, 2010 | 12:41 PM
hitman619's Avatar
hitman619
SDSU Basketball
Can you give us some more information.
Old Apr 22, 2010 | 12:51 PM
Love2RedLine
My 4th Acura
The engine is a b20 w some cams and a few internal mods. Is there any other info that will be helpful?
Old Apr 22, 2010 | 09:46 PM
Spec R's Avatar
Spec R
hate to break it to you, you'll never be able to pass smog.
B20s are considered truck/suv motors and according to the CA bureau of automotive repair (BAR), cannot placed into cars.
if you get a referee ticket, they can impound your car.
on another note, what specifically is failing the test?
DB Squad
Integra Forum Moderator
Old Apr 23, 2010 | 09:51 AM
Love2RedLine
My 4th Acura
Yeah bro I know about the B20 issue. Some one was able to hook it up for for me last year; this is what I need again. Some of my numbers are just too high.
Old May 6, 2010 | 07:54 AM
ReaperOne's Avatar
ReaperOne
Try going to a regular smog place and get a diagnostic done. I am going to have this done on my 96 Ls. I have a stock b18b1 engine, but failed smog and now car is considered a gross poluter, but got the smog at a test only place and they dont give repair information. So going to get a diagnostic test done to determine the issue so it can be fixed. most places wont look to see if the engine matches the car, so as long as you fix what is causing it to fail smog, then you should have no problem. I have a buddy that did a H22 swap in his civic hatch and passed smog with no problem, because the place didnt check to see it wasnt a civic engine, just saw honda and did the test. . . The B20 should not be that different from the B18, it is pretty much the same motor, even the JDM places state the B20 is for the CRV or Integra, so look wise, if you have the big intake manifold, they should be identical. . .
Old May 15, 2010 | 09:40 PM
cruzalekz's Avatar
cruzalekz
need to get rid of the cams. the cams were designed to make power sacrificing emissions. put oem back.
