Crank is jammed
Old Mar 28, 2003 | 09:03 PM
The Bum's Avatar
The Bum
Black people go wooooo
Default Crank is jammed
I took the head of my ex motor (d16y8) and did some work, and then put it back on. It worked, and then I took the head of again to put on a new head gasket. When I try to start it, the crank will not turn. I turned the crank manually, and it has about 270 degrees of motion, and then it stops. I thought that a valve was hitting a piston, so I took the head off and tried to turn the crank. Still, it siezes... Any ideas??
Old Mar 30, 2003 | 09:42 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
I would drop the pan and take a look.
Old Mar 31, 2003 | 10:45 AM
rev's Avatar
rev
Not good. Drop the pan and see. Did you do ANYTHING else to the engine?
