What is needed to replace my 94 B18B with a 96 B18B
Old Apr 16, 2010 | 09:57 PM
ari_one's Avatar
ari_one
Default What is needed to replace my 94 B18B with a 96 B18B
Tried searching but didn't find an answer. What exactly do I need to do to drop a 96 B18B1 into my 94 LS?
Old Apr 18, 2010 | 05:03 AM
8secHonda's Avatar
8secHonda
if u had a b18 n it before it should be just as easy as dropping it in bro.. dont think anything changed between those years
Old Apr 18, 2010 | 06:54 AM
ari_one's Avatar
ari_one
The 96 is OBD2 while my 94 is OBD1 so I'm assuming there must be something different.
Old Apr 19, 2010 | 11:26 AM
8secHonda's Avatar
8secHonda
If ur just using the engine itself it should be ok... I will do some research n find out 100% for u ..
Old Apr 21, 2010 | 09:36 PM
ari_one's Avatar
ari_one
Thanks, would appreciate it.
Old Apr 22, 2010 | 10:01 PM
Spec R's Avatar
Spec R
use the intake manifold, distributor, fuel injectors, sensors etc from your 94 b18b1 on the newer one. basically anything OBD2 on the new motor will NOT work with your old motor
DB Squad
Integra Forum Moderator
