fuel filter/pressure
Old Mar 26, 2010 | 10:30 PM
keepinabeat's Avatar
keepinabeat
Default fuel filter/pressure
i have a gauge on my fuel filter car is runnin like shit i think the filter is clogged if i open the throttle the pressure should rise with the engine right?
Old Apr 2, 2010 | 06:24 AM
8secHonda's Avatar
8secHonda
do u mean u have a fuel pressure gauge or regulator on ur fuel line? im assuming it is on a electronic fuel pump and not mechanical- it wont raise pressure on a electronic fuel pump they are set to operate at a certain pressure. hope this helps not sure what u need to know exactly.
Old Apr 3, 2010 | 12:24 PM
Lynxs1981's Avatar
Lynxs1981
Correct, the pressure should rise with engine RPM.
Old May 5, 2010 | 10:12 PM
A-dub5513's Avatar
A-dub5513
I know this thread is a month old, but did you ever figure out what the problem was? I'm curious because I've been experiencing the same problem with fp's not building. I originally thought it may have been my fuel pump dying a slow death. Turned out to be fine. So I've replaced the fuel filter just today (80,000 and my first filter replacement ). Although it appears that the car drives/sounds smoother, pressure isn't building as fast as it should.
A
