MrFatBooty is a FAKE!!
Old Mar 25, 2003 | 04:53 AM
NVS's Avatar
NVS
That's Mr.NVS to you!
Default MrFatBooty is a FAKE!!
Not really, just wanted to get your attention. Any ways, I looked at those pictures that show how to adjust the idle speed. Instead of doing steps 1-5, I just turned the idle adjusting screw. Will that hurt anything?
Change the subject of this if want.:grinpimp:
Old Mar 25, 2003 | 05:48 AM
cvc2k's Avatar
cvc2k
That depends on your luck. I don't have the manual on me at the moment, but if it idles fine, then u should be ok for the most part. Check timing afterward.
Old Mar 25, 2003 | 08:33 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
MrFatbooty rocks!
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Mar 25, 2003 | 09:23 AM
NVS's Avatar
NVS
Originally posted by import-tooner
MrFatbooty rocks!
you betcha
Old Mar 25, 2003 | 09:53 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If you don't unplug the IACV, you could adjusting the idle speed while it's still being IACV-controlled. If you adjust it to what you *think* is the stock idle speed, when the IACV shuts off, your idle will be low, or you may even stall out. You basically want to adjust the idle speed with the IACV disconnected, and no electrical load(A/C, radio, etc).
