Fuse stuff
Old Jun 26, 2002 | 06:58 AM
smakdown's Avatar
smakdown
Default Fuse stuff
I just bought some new foglights and instead of tapping into my parking light wire, i bought one of those add-a-circuit things that taps into the fuse. The only problem is that my parking lights use a 15 amp fuse but the add-a-circuit can't use anything higher than 10 amp fuses. I was going to buy a 10 amp to replace the 15 amp but im not sure if this is safe or not. I know there is some kinda rule but i can't remember if it says that you can't use a higher amp fuse for a lower one or lower amp fuse for a higher amp one. Any ideas???
Old Jun 26, 2002 | 07:43 AM
Soulja's Avatar
Soulja
HAN's resident 5-0
You should be fine putting a 15 amp fuse in the add-a fuse
Old Jun 26, 2002 | 08:02 AM
smakdown's Avatar
smakdown
in the directions it specifically says "place the original fuse (NOT TO EXCEED 10 AMPS) into slot A..."
Old Jun 26, 2002 | 10:34 AM
smakdown's Avatar
smakdown
Just a simple wiring question...i know one of you guys out there knows something...
Old Jun 27, 2002 | 01:01 PM
smakdown's Avatar
smakdown
installing tomorow, don't wanna cause a fire...
Old Jun 27, 2002 | 01:47 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
pay 20.00 for a pro to do the wiring. Trust me if you have doubts just let the pro do it cuase if anytihng goes wrong you'll spend alot more replacing lets say... a Multiplex box ahahhaha learned my lesson (80.00 used from a salvage accord \ 350.00 from honda dealer) i was doing some wiring of my own
Old Jun 27, 2002 | 01:52 PM
smakdown's Avatar
smakdown
I've done this many times before and never had any problems. This is the first time ive encountered the fuse problem though. The wiring is easy.
Old Jun 27, 2002 | 02:12 PM
parcero's Avatar
parcero
go ahead and throw in the 10amp fuse. The worse that can happen is that the fuse will blow.
Fellsbells
Mar 26, 2006 06:22 PM
Acura_I-RS
Mar 11, 2005 05:28 PM
epoxy
4
Jul 5, 2003 11:30 PM
