Head swapping??Help
Old Mar 19, 2003 | 11:35 AM
15sCivicRedline's Avatar
15sCivicRedline
Default Head swapping?? PLEASE Help!
I want to know if a d16y8 head will swap onto a 1995 DX (d15b7)? and also am I able to use the throttle postion sensor from my d15 b/c the one i want is missing that.
Old Mar 19, 2003 | 02:08 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
It should bolt up, and I believe the TPS should work, but I can't remember if the OBD generation matters or not.
Old Mar 21, 2003 | 05:44 PM
S.I.K Prelude's Avatar
S.I.K Prelude
I AM PRETTY SURE THAT THE TPS SHOULD WORK. I PUT A TPS FROM A 92 CIVIC 1.5 ON A 99 B16 MOTOR AND IT WORKED FINE I DONT THNK IT IS POSSIBLE TO UES THAT HEAD ON THAT BLOCK THOUGH . THE HEAD GASKETS ARE DIFFERENT.
Old Mar 21, 2003 | 07:48 PM
drift's Avatar
drift
Flaccid Member
88-91 Civic DX D15's TP sensors wont swap over. the run backwards of D16 TP sensors. only the 88-91 Si D16 TP sensors, and 92+ sensors are interchangeable.
Old Jul 5, 2005 | 11:00 AM
mutt_1986's Avatar
mutt_1986
me and one of my buddies put a y8 head on a d15b1 and it was successful. the headgaskets are the same some wiring was involved to convert to mpfi. but that was the hardest part
Old Jul 5, 2005 | 11:28 AM
b16ahybrid's Avatar
b16ahybrid
Yes the y8 head will swap on to your b7 block, not sure on the tps but I would imagine that it would swap also...
