NooB Question about turbos
Old Mar 17, 2003 | 06:44 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Default NooB Question about turbos
Like i said this is proboly a noob question, but what its the wastegate for and the blow off vavle for? Also which is better and why internal or external wastegates. Thanks for the helping an interested mind
Patrick
Old Mar 17, 2003 | 06:49 PM
Snoopy's Avatar
Snoopy
been there done that
wastegate regulates boost and blow off valve releases built up pressure from the intake pipe when the tb plate closes so it doesnt get forced back into the compressor. external wastegates are better cause they allow you to run more boost. most factory turbo'ed cars have an internal wastegate.
Old Mar 17, 2003 | 07:33 PM
DSC's Avatar
DSC
Long way from home
The wastegate releases the extra air the turbo generates. For example if you have a wastegate at 8psi it cannot go over 8psi.
When you shift the TB plate closes causing a surge of air back toward the turbo. This is of course bad (its spinning one way @ like 50,000 RPM, then gets stopped). The BOV releases this surge.
Old Mar 17, 2003 | 07:48 PM
HatchVX's Avatar
HatchVX
ah i see. thanks guy for being patient with me.
Old Mar 18, 2003 | 12:50 AM
drift's Avatar
drift
Flaccid Member
uh, the wastegate vents exhaust gas away from the turbine to regulate boost.
not that it releases pressurised air. big difference, as you described a popoff valve.
Old Mar 18, 2003 | 09:48 PM
Sportmode's Avatar
Sportmode
imagine blowing through a straw (your mouth is the turbo here) if you cover the end of the straw (closing the TB plate) you have a bunch of air with no where to go. A blow off valve opens up when the tb plate closes to release the air. Oh and btw im pretty sure that anything with an external wastegate is not street legal, not that anyone really cares anyway.
Old Mar 19, 2003 | 12:07 AM
drift's Avatar
drift
Flaccid Member
not street legal for CALI.
there are 49 other states that arent emissions nazis.
Old Mar 19, 2003 | 10:11 AM
s1267712's Avatar
s1267712
I think it might be legal if you vent it back into the exhaust, rather than venting it to the atmosphere, but maybe not in CA? I dunno
Old Mar 20, 2003 | 03:49 AM
drift's Avatar
drift
Flaccid Member
some of the new turbo kits coming onto the market are featuring closed loop, external wastegates and are being applied for CARB certification.
JG's system is one of them.
Old Mar 20, 2003 | 07:58 AM
s1267712's Avatar
s1267712
yeah, a closed loop external is no different than an internal as far as emissions go.
