Swapping engines
Old Jun 24, 2002 | 09:17 PM
Dragonboy888's Avatar
Dragonboy888
Default Swapping engines
Does anybody know if a s2000 engine would fit in a 97 honda special edition? if not anybody know what would be a good engine to put in one? thanks
Old Jun 24, 2002 | 09:51 PM
sLoW aZZ aCcOrD's Avatar
sLoW aZZ aCcOrD
ummmm since your probably new i'll be nice. you cant swap a S2000 engine into your accord. the S2000 engine is unique. it is the only rear-drive car honda makes besides the NSX and that is a mid-engine car. dont get me wrong if you have tons of money to spend and find a very good mechanic then anything is possible but realistically you cant do it.
Old Jun 24, 2002 | 10:46 PM
oofrost's Avatar
oofrost
The S2000 is a FR layout. The engine is not in the middle.
The Accord is a FF car. Front engine/front wheel drive. It will fit, but you would buy a S2000 for the cost.
Old Jun 25, 2002 | 08:31 AM
v4lu3s's Avatar
v4lu3s
well
no one mentioned the fact that the f20c also rotates in the opposite direction as almost every other honda engine (cept for K series).
Old Jun 30, 2002 | 05:58 AM
Dragonboy888
hey guys thanks for your input. i wasn't sure if it was possible to put that engine in i just mentioned it and some guy said it was possible. by the way do any of you go to summit point raceway? if u guys are in the maryland area.
Old Apr 8, 2003 | 10:30 AM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
So then would it be possible to mate the F20C with the F22b1 tranny?? I know the tranny would have to be rebuilt.
Old Apr 8, 2003 | 10:32 AM
v4lu3s's Avatar
v4lu3s
not likely sonce as far as i know the engine rotates the wrong way so you would have 5 speeds in reverse and one in forward....least that is way i think it would work.
Old Apr 9, 2003 | 10:07 AM
vtecaccord01
So then what if you rotate the starter so it spins the otherway.
Old Apr 9, 2003 | 10:12 AM
v4lu3s's Avatar
v4lu3s
i somehow suspect that you will be in the middle of an engineering nightmare....think about everything that counts on teh engine rotating one way...such as the ecu, sensors in teh distributor and block and so on.
with an f20c, K or J series you eitehr go rear wheel drive or have the tranny on the driver side.
Old Apr 9, 2003 | 10:44 AM
vtecaccord01
so then jdm transmisson.
