Grounds?
Old Mar 15, 2003 | 08:22 AM
v-teg01's Avatar
v-teg01
Candy
Default Grounds?
Does it really make a difference in the way the car runs by beefing up my ground wires. If i did i would'nt feel anything only see it in the way my car idles, and so on?
Old Mar 15, 2003 | 08:34 AM
antarius's Avatar
antarius
Large Member
You read too much ImportTuner, but according to them; yes you can notice a difference in power.
I would'nt waste your time. Just make sure your stock ones are in good condition.
Old Mar 15, 2003 | 09:29 AM
XSrcing's Avatar
XSrcing
i wouldnt worry about it unless you are running some heavy duty electronics in your car. if you make sure the stock ground straps on your car are in good order you will be fine.
b00gers's Avatar
b00gers
depends how old your car is. with better grounds you MIGHT be able to get your car to run smoother. especially if you have a big system in your car, or if your grounds are messed up to begin with. because grounds do get old.
