91 Integra That Surges At idel?
Old Mar 13, 2003 | 11:19 AM
skeeterDX's Avatar
skeeterDX
Default 91 Integra That Surges At idel?
Quick tech question:
I have a 91 integra, when the car idels it surges from 1,000 rpms to 2,000 rpms and idea what this could be??
we get no check engine lights
Old Mar 13, 2003 | 04:28 PM
ambition's Avatar
ambition
StillDPG
reset ecu and adjust t.b. screw, would be my first move
Old Mar 13, 2003 | 05:13 PM
90'RS's Avatar
90'RS
the screw wouldn't make the idle jump just high or low but if you place this in the engine tech forum you might get a bigger and more informative response.
Old Mar 13, 2003 | 06:20 PM
ambition's Avatar
ambition
StillDPG
is you car an auto or 5 spd doe the idle flux when you are stopped and on you brake, could it be your a/c is on. when does it happen? does it do it all the time? when its cold?
Old Mar 13, 2003 | 07:03 PM
skeeterDX's Avatar
skeeterDX
Default hmm
There is no ac in the car... and it only seems to do it when the car has warmed all the way up.
when it's at a stop light it does it or any time the car is at a idel.
Old Mar 14, 2003 | 07:29 PM
g2tegls's Avatar
g2tegls
MR, ftw
check the coolant :thumbup:
Old Mar 14, 2003 | 08:16 PM
XSrcing's Avatar
XSrcing
how fast does it surge? vacuum leak is the first thing that comes to my head. but if your coolant is low, air pockets could be going through the fast idle valve causing it.
