tranny fluid for '91 gs??
Old Mar 12, 2003 | 11:01 AM
paymepunk's Avatar
paymepunk
Default tranny fluid for '91 gs??
i ahve a quesation.. i am at work and if someone could give me a solid answer by 5 i'd appreciate it. my'87 teg takes 10w30 in the tranny...wierd thing about 1st gen tegs. okay the setup and the chilton manual are the sdame for my new '91 gs... i have only found material saying to put motor oil in the tranny as well... can this be true??? I called three places and all their litterature said 10w30...wierd..so i will go ahaed with the at unless someone can find me a page that rexplains my alternatives..
on the upside.. i can change my trannuyfluid the same time i change my oil with no probs and only 5 extra minutes.
let me know of there are safe!!!! alternatives to 10w30 that have been published sonce my ancient chilton manual..
thanks guys
Old Mar 12, 2003 | 11:38 AM
Jokieman31's Avatar
Jokieman31
That'd be Gear Oil, not motor oil. I'd hope anyways. Never heard of a tranny taking motor oil, not in new cars anyway.
I take it it's a manual transmission?
Old Mar 12, 2003 | 11:44 AM
Jokieman31's Avatar
Jokieman31
Ok, Wow, Amazing, I'm wrong. use motor oil.
got this from autozone.
www.autozone.com
'87 integra, manual tranny.
Current
Vehicle: 1987 ACURA INTEGRA
4 Cylinders 01590 1.6L FI CHANGE
TRANSMISSION FLUID TYPE
For your 1987 ACURA INTEGRA:
SPEC-FLUID-TYPE/WT SG - MOTOR OIL
WEIGHT = 10W-30, 10W-40
So sue them if it's wrong. hehe.
Learn something new every day, I wonder if you could use synthetic? hehe.
BTW that's for "All Weather fluid type" and for "Manual Transmission"
For Automatic's it's
SPEC-FLUID-TYPE/WT AF - DEXRON III
Old Mar 12, 2003 | 12:05 PM
kidM0UA's Avatar
kidM0UA
i use mobile 1 synt. 10-30 oil in my tranny...(GSR)
no problem
Old Mar 12, 2003 | 02:06 PM
90'RS's Avatar
90'RS
only use honda fluid because of it's additives they put into it. Oil can be used for a temp. situation. It most likely never cause a problem but why take the chance when honda doesn't charge to much anyways.
90'RS's Avatar
90'RS
also try the search button this has been discussed before.
