Where to get the Crank Pulley tool online?
Old Mar 8, 2003 | 10:35 AM
AXiS's Avatar
AXiS
Default Where to get the Crank Pulley tool online?
Hello all.. been a long time since I posted here, but I know someone in here has the answer to this. I am changing my timing belt on the ol' integra, and need some help finding the crank pulley tool that you can use to stop the crank from rotaing when removing the pulley. I tried to get the crank pulley bolt off with 2 different impacts, but they were no use since the crank just rotates every time the impact hits. I found a company online that makes the tool I need, but I can't find anywhere to buy it. The place I found that makes the tool is called powerbuilttools.com and I am assuming that I would need the 50mm one that they sell, part number 648796. If anyone knows where to get that or another tool like it online, for a reasonable price, please post it here so everyone can benefit. I already tried searching this, and found some info about what the tool is and everything, but there are no listed places to buy it. Thanks for any help.
Old Mar 8, 2003 | 01:38 PM
g2tegls's Avatar
g2tegls
MR, ftw
http://store.summitracing.com/partdetail.asp?part=23351
I just put an allen wrench into the flywheel teeth, but then again I'm ghetto h:
Old Mar 10, 2003 | 07:57 AM
AXiS's Avatar
AXiS
Yeah that would work if I had a manual tranny, but then again if I had a manual I could just put it in gear and the brakes, too. It' an automatic, however.. so that' why it sucks.
Old Mar 10, 2003 | 06:23 PM
g2tegls's Avatar
g2tegls
MR, ftw
yeah that didn't work for me :dunno: use the tool! :fawk:
Old Mar 10, 2003 | 06:59 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
When i took the crank off my civic all i did was put a screwdriver in the fly and it worked. In an auto u should be able to put it into park to lock the tranny this locking the crank right??
Old Mar 11, 2003 | 06:20 AM
JimBlake's Avatar
JimBlake
If that locks the crank, then your engine would have a hard time idling when the transmission's in park, no??
Old Mar 11, 2003 | 07:07 AM
qtiger's Avatar
qtiger
The Moroso tool is the best item you will ever purchase.
Keep it next to your bed... someone messes with your car, give 'em a 55mm in the face.
Old Mar 16, 2003 | 10:12 AM
AXiS's Avatar
AXiS
Yeah I ended up getting the moroso tool, that thing is huge! The only thing that sucks about it is the fact that I probably won't ever use it again, thus making the 75 dollars kinda a waste.. but at least it's still going to come out much cheaper for the timing belt change than if I got it done somewhere.. plus I got a 20.00 certificate from summit to use on anything they sell, so I got a dual gauge pod for my a pillar in my eclipse gs-t for like 12.00 shipped.
Old Mar 16, 2003 | 10:15 AM
nevets's Avatar
nevets
WAAAGH!!
heres another use:
:chuckles:
