coil over clunking and squeeking
Old Mar 7, 2003 | 08:17 AM
Neur0sis's Avatar
Neur0sis
Default coil over clunking and squeeking
Hey kids...
Just wanted to know what you guys do about the strange sounds that come from your coil-overs when it gets cold? There are several different sounds coming from the rear... from clunking, to creaking and squeeking.
Is there anywhere I should lube up? Bushings, or the seats of the coilovers? I have also heard about coating the top section of the springs with rubber to subdue the "clunk" noise when gong over bumps...
Any insight?
Old Mar 7, 2003 | 08:49 AM
90'RS's Avatar
90'RS
rapping the spring with rubber only helps with a progressive spring where they wind closer together towards the top. As for stopping I don't know but I'm sure someone else will be able to help you.
Old Mar 7, 2003 | 02:59 PM
r2d97's Avatar
r2d97
I think it might be the rubber o-rings are out of adjustment on the shock. I have ground contols and I am switching to the eibach pro kit this weekend because mine were doing the same thing. You should take your suspension apart and check to see if thats what it is.
Old Mar 7, 2003 | 04:30 PM
LT's Avatar
LT
The deer had to die!
mine does too...i think its just how it is on lowered coilovers. Oh well, the music is on so i don't hear it too often.
Old Mar 8, 2003 | 08:51 AM
Charged-GSR's Avatar
Charged-GSR
im not sure but mine makes the same sound and i have a feeling its the bushings in the camber arm doing it- mine seemed to start after i dropped the lower perch on the konis another notch for a lil extra drop?? but still only does it when the weather is cold
maybe its actually inside the shocks are you guys running yellow konis too??
Old Mar 8, 2003 | 09:47 AM
Osman's Avatar
Osman
I'm running tein SS and I get strange noises too...
