Question antenna...
Old Mar 5, 2003 | 06:03 AM
Heinz57's Avatar
Heinz57
Default Question antenna...
I have a question about my antenna. Today when I was done listining to my radio I turned it off and noticed that the antenna did not go down like it usually does. Can any one tell me why its doing this. Oh yeah it has been lubed at the dealership all the time. Its my frist problem I had with it.
Thanx
Heinz
Old Mar 5, 2003 | 06:22 AM
teg_fan's Avatar
teg_fan
I like integra's
I would say check if the motor is bad on the antenna or if it is connected properly. Was there any noise at all when you turned off your radio??
Old Mar 5, 2003 | 06:30 AM
97integraLS's Avatar
97integraLS
I had a problem like that with mine... the antenna becomes very weak and cause a lot of friction (especially in the snow) this friction breaks down the atennas smooth up down action and sometimes jams it... you can try oil on it... or replace the part
Old Mar 5, 2003 | 07:23 AM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
S2k antenna is calling your name
Old Mar 5, 2003 | 10:50 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
If you had it lubed at the dealership, you may want to ask them to check the motor next time you bring your car in. I had the opposite problem where the antenna would be stuck in the down position and wouldn't go up, but it ended up being a problem with dirt getting stuck in the threads.
Shingo
Old Mar 5, 2003 | 11:18 AM
Heinz57's Avatar
Heinz57
Default anyone else.....
the antenna motor sounds the same just like if it was going down or up. The antenna also doesn't feel jammed or anything because I can turn it. The only problem is that it will not go down. Can I fix it myself if I find out what it is?
mrhonda_187's Avatar
mrhonda_187
Mine wouldn't go down all the way. Dealership 'replaced the mast'. Hope that helps.
00' Teg GS.
Old Mar 5, 2003 | 11:36 AM
Heinz57's Avatar
Heinz57
Default Is the......
mast a motor or another piece. And for how much
Old Mar 5, 2003 | 11:52 AM
mrhonda_187
No, it had nothing to do with the motor. I'm under the impression that the 'mast' is the telescoping piece? However, I suppose it could be the piece that rides up inside the telescoping piece? Anyone have an exploded diagram? This was done under warantee, so no charge. I'll keep getting it fixed until my warantee runs out, then I'll probably go with the S2K 'fix'. Integra antennae problems are very, very common. Suprised there hasn't been a recall.
