Help engine code 6
OK heres the deal....
OBD2 B16a2, Swapped in 99 civic ex.
I am using OBD2 B16a2 Comp.
OBD2 B16a2 Wiring harness.
and i had a check engine light, and i checked it by touching the 2 connectors by the ecu, and it blinked 6 times fast.
What is it, what do i do?
Secondary, im missing the front left (opposite tranny side, right by the ac pump), im missing that mount. will it really affect my driving or is it ok? if i drive it do i have to baby it till i get that mount or do i need it? what will happen if i drive without it?
thanks guys.
thanks guys.
6 is ECT - engine coolant temp sesor. Make sure the sensor's plug is connected to it(the sensor is located ont he head, under the distributer).
The front torque mounts keep your engine from rocking back and forth. If you're missing the driver side one, than that side of the engine is being supported by the upper driver side mount alone. If you run like this your engine will move around quite a bit, which will wear out the other mounts, and their rubber components will eventually tear. I would not drive very long, if at all like that.
