short throw shifter question...
Old Jun 20, 2002 | 08:38 PM
mikesudds's Avatar
mikesudds
supa dupa member
Default short throw shifter question...
i recently received an APC short throw shifter for my birthday from my mother.......it is the one designed for the civics...you know the generic one. ...before i get flamed i am a NEWB! but i am learning everyday...anyway the shifter works great i really like it. but it makes a rattling noise when the car gets around 1500 rpm's. anyone else had this problem?? just curious what could be done to fix it.
thanks
mike
Old Jun 20, 2002 | 09:32 PM
LT's Avatar
LT
The deer had to die!
mine does it only when i'm revving down (I have a REAL short shifter - skunk2)...its just because of the resonation
Old Jun 20, 2002 | 09:52 PM
94tegAddict's Avatar
94tegAddict
it's common problem with low budget short shifters. try to tighten up the bearing, or see if it's touching the exhaust piping. i have skunk2 short shifters, and it does not rattle
Old Jun 21, 2002 | 05:07 AM
PatrickGSR94's Avatar
PatrickGSR94
I'm not a n00b!
I have a generic short throw, and it does not rattle at all. It came w/ 2 spacers, which I placed one on each side of the bearing in the bottom of the shifter. I then used washers on the stock through-bolt to take up the rest of the space on the bolt, along w/ a lock washer, and everything is nice and tight w/ no rattles or problems whatsoever. :thumbup:
Old Jun 21, 2002 | 05:49 AM
Madtekniques's Avatar
Madtekniques
cryoteknical
The way that short throw shifters work is that they are longer on the bottom ie. from that pivot ball down. This is so that you have to push/pull it less distance up top to move it further down below thus giving you shorter throws. So........sometimes they hit the heat shield that is blocking the cat. Any brand can have this problem the generic ones or the expenxive ones. You could get under the car and bend the heat shield just a little bit so that is won't hit.
Good luck
Old Jun 21, 2002 | 07:51 AM
mikesudds's Avatar
mikesudds
supa dupa member
hey would/could it damage anything if i just took the heat shield off altogether? thanks for the reply's
mike
Old Jun 21, 2002 | 08:49 AM
PatrickGSR94
I'm not a n00b!
mike
The shifter might get a bit hotter, which will make a difference if you have a metal shift knob. My generic short-throw did not hit the stock heat shield at all. The heat shield is gone now, so there is even more room down there. I don't believe it would damage anything, just don't ever park your car over tall/thick grass and/or dry leaves or stuff like that.
SHEERKON
Jul 13, 2004 02:02 PM
RedDemonSA
92+ Civic/EL & Del Sol
19
Jan 31, 2003 07:38 PM
PSPEC
Sep 17, 2002 03:34 PM
PSPEC
Accord
Aug 15, 2002 04:54 AM
EJ6 Civic
6
Jul 1, 2002 06:42 PM
