h23 in 92 accord
Old Jun 20, 2002 | 07:31 PM
92hybrd's Avatar
92hybrd
Default h23 in 92 accord
need help i have a 92 aCCORD with a 95 h23 tranny in it already now i have the motor what all do i need to do the swap will it just bolt up and how do i wire it up thank u all help will help! :awais:
Old Jun 21, 2002 | 10:47 AM
v4lu3s's Avatar
v4lu3s
it drops right in with all accord mounts
bolts right up
you have to change the plug on the EGR and the Oil Pressure Sensor, and then add the IAB wire(only if yo uhave a dx/lx), and add the kncok sensor wire.
Old Jul 11, 2002 | 02:17 PM
92hybrd's Avatar
92hybrd
what is a iab wire and how do i do that. also the egr and oil pressure plugs do i just cut the prelude ones off the wiring harness and put them on the accord harness. doe's the h23 ecu just plug in to the accord harness in the car. the kncok sencor wire add this where. if any one can help or know where there is a step by step web page or some thing i've never done this and i live in tenn and there are no shops close to me that will do this.
thanks
Old Jul 11, 2002 | 03:58 PM
v4lu3s's Avatar
v4lu3s
for the oil pressur just cut the prelude eyelt off and solder it to the accord one. you can also swap the accord egr over to the prelude intake, that might be easier so no wiring has to be done. the IAB is the secondary runners, its a black box with a round plug under the manifold, one wire goes to the ecu one to the common power (yellow and balc wires), and then knock sensor you jus add the wire and plug and run it to the ecu.
no step by step i really know of, if you dont already have a manual with wiring diagrams for your accord and for the prelude engine, you need to get them.
Old Jul 25, 2002 | 07:27 PM
92hybrd's Avatar
92hybrd
the iab wires witch one go's where
Old Jul 25, 2002 | 07:28 PM
v4lu3s's Avatar
v4lu3s
black/yellow is common power and the other one goes to a17 on the ecu i think...you may want to double check the pin on your wiring diagram though...same pin on h23, f22a6, h22, and b18c1 though.
Old Jul 25, 2002 | 07:35 PM
92hybrd's Avatar
92hybrd
so where would i find common power sorry so many ? but i want this right and i've never done this befor thanks for every thing so far
Old Jul 25, 2002 | 07:39 PM
v4lu3s's Avatar
v4lu3s
no problem...the black/yellow wires all go together to a plug that links em all up...its common power for all the sensors on teh engine.
Old Jul 25, 2002 | 07:42 PM
92hybrd's Avatar
92hybrd
i wastold i have to change the p/s pump to the h23 is that true
Old Jul 25, 2002 | 07:46 PM
v4lu3s's Avatar
v4lu3s
its a lot easier to use it....you will also need the prelude si/vtec power steering hose for a straight bolt in on power steering.
