Noise!!!!
i got a 00 coupe only 24k. The rear is making creeking noise when ever i go over speeed bumps or make turns also when ever people sit in the car and it would make this Creeking sound like metal rubbing together. I think it might be the springs... do any of you guy have this problem?
Creeking like old bed springs? Is it worse on cold days? Hit your bushings (all the rubber grommets and gaskets pieces that are in your sway bars, and other suspension pieces under the car) with some liquid silicone spray, that may be all you need to do. My 92 and 96 accord used to do teh same thing on cold days over speed bumps and dips.
Mine does the same thing on cold days...so you're saying all you have to do is spray it with silicone spray? Did it go away?
its only a temp fix though, next season you may have to hit them again. Not a big deal though, just get em while doing an oil change.
