90 crx hf hesitation up to around 2500 rpm
Old May 31, 2009 | 08:19 AM
airmechanical@sbcg's Avatar
airmechanical@sbcg
Default 90 crx hf hesitation up to around 2500 rpm
Hello everyone. I have a 1990 Hf, I have a hesitation from idle to about 2500 rpm under a load (and only under a load). This is what I have done and checked out: Major tune up including NGK plugs, honda wires, cap, rotor, pcv, fuel filter, air filter, injector cleaner, timed the engine. I unplugged the tps and the car run smoothly, smogged it the other day and it failed on both HC and CO. I was told it could be the tps, but I am wondering if it could also be the ecu or tps wiring to ecu. Also, why would the car run smoothly with the tps unplugged. Thanks for any help you can provide.
Last edited by airmechanical@sbcg; May 31, 2009 at 08:20 AM. Reason: Accidental quote
Old Jul 27, 2009 | 08:53 PM
93hondablk's Avatar
93hondablk
gtr
Yea I think it might be the ecu
Old Jul 29, 2009 | 09:23 AM
cruzalekz's Avatar
cruzalekz
tps is a major input. if you unplug it, the cel will be lit and your pcm goes into back up mode.
car runs but will not be perfect coz your pcm is basically relying on your map sensor (partner incrime of tps) .
you could actually test the tps with the voltmeter with the key in the "on" position only, backprobe the signal wire and move the throttle slowly back and fort you are looking for a sudden drop in the voltage from .5 to 4.8 volts
