Honda Accord Coupe 98-00: Grillcraft Sport Grille (Upper)
Old Jan 19, 2003 | 01:50 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Default Honda Accord 98-02: Grillcraft Sport Grille (Upper)
Import Street Scenes - News, photos, videos and info .. straight from the streets!
http://www.importstreetscenes.com
Thanks www.accordracing.com for the DIY
- This is the Project Accord before installation
- Remove upper grille clips using a flathead screwdriver
- Remove lower bumper clips using a flathead screwdriver.
- Remove the bolts located in right & left upper fender well corner
- Remove the bolts located in right & left lower fender well corner.
- The bumper cover can now be removed from the vehicle.
Old Jan 19, 2003 | 01:56 PM
98CoupeV6's Avatar
98CoupeV6
- Remove original grille.
- Place the GrillCraft Sport Grille into the bumper.
- While holding the grille firmly in place mark the mounting tab screw location.
- Using a 3/16-drill bit, drill bracket mounting screw holes.
- Install the Sport Grille with supplied fasteners as shown.
- Wow what a difference.
- Shown here with the optional lower grille kit
