89 CRX si radio install problems. HELP!
Old Jan 16, 2003 | 10:37 PM
SilverMPower's Avatar
SilverMPower
Default 89 CRX si radio install problems. HELP!
I just bought an 89 CRX si that did not have a radio installed. The wire harness has been cut so there is no plug to go into a Honda radio I had in my garage. Fortunately, I had a cut adaptor with the radio. Now...the problem is I cannot get this damn thing to work. I matched all colors, but have the following strays:
On the harness side, I have a Yellow/Red wire that I imagine is the constant, but the adaptor does not have this color. On the adaptor side, I have a White/Blue and White/Green that the harness does not have.
Any ideas?
TIA!
Old Jan 17, 2003 | 04:42 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
If it were an aftermarket radio, I may be able to help you more, but since it isn't, you'll likely have more luck in the audio forum, which is where I'll move this for you.
-Harry
AIM: NDcissive
Old Jan 19, 2003 | 06:01 AM
purplx's Avatar
purplx
check www.installdr.com and click on the quick wiring box. you may find at least 1 answer there (and a diagram)
