What do I need to boost higher?
Old Jun 18, 2002 | 11:18 AM
integramodder's Avatar
integramodder
Default What do I need to boost higher?
What internal upgrade should I do to boost higher?
like pistons, rods, rings, valves, springs, etc. ?
Old Jun 18, 2002 | 07:27 PM
zAd -'s Avatar
zAd -
only need to modify the block to handle boost like piston and rods. u dont really have to modify the head
Old Jun 18, 2002 | 07:43 PM
qtiger's Avatar
qtiger
Sleeves, rods, and pistons would be ideal.
Old Jun 19, 2002 | 01:06 AM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
Bah first thing is get better fuel management. Stock block can take a lot if you just get it properly tuned. Blockguard is nice and cheap too...just make the coolant holes bigger and you should be fine.
Old Jun 19, 2002 | 07:12 PM
AP2's Avatar
AP2
Moderator Alumni
The key word is Fuel
Old Jun 20, 2002 | 07:13 AM
integramodder
Whats blockguard?
Old Jun 20, 2002 | 07:27 AM
integramodder
also, what do you suggest for fuel management?
I was thinking AEM EMS, walbro HP intank pump, (vortec or aem) fuel rail & fpr, RC 440 cc injectors.
Old Jun 20, 2002 | 09:20 AM
'98tegls's Avatar
'98tegls
It all depends on your definition of high boost. If 30 lbs. of boost is high for you, then you'll need a fully built block. If your thinking 20 lbs. of boost is high, then all you need is Hondata 4b and blockguard.
The AEM EMS isn't fully developed yet. The software needs to be updated before it can be as beneficial as Hondata. The software is so bad that even people trained by AEM have blown up a few engines.
Old Jun 20, 2002 | 02:19 PM
Assman's Avatar
Assman
If you run lean, wave bye-bye to Mr. Motor.
Old Jun 20, 2002 | 04:10 PM
'98tegls's Avatar
'98tegls
Originally posted by integramodder
Whats blockguard?
Blockguard slides into the Block Sleeve to provide extra strength to the block, hence the name.
