New Generation of CL / TL??
Hey guys! I'm new at the forum and was wondering when the CL or the TL will change its look. I'm looking for a new car to buy in the summer and was wondering if a new generation is coming out... should i wait?? Does anyone have any info on the new generation. Replys will be much appreciated. Thanks
Is a TL or CL the type of car you're looking for??
As far as I know, there is no word of a re-design yet. As you may or may not know, Honda likes to keep their cars fresh looking... so new models come out usually every 4 years... in 99 the 2nd gen TL came out... and in 2001 they re-designed the car lightly... mostly making the grille and headlights larger... some other changes were made... and they added the type-S version. It'd seem that 2003 would be the year of a re-design... but its not... i'm assuming they are going to bring out a new TL and CL at the same time.
The 2nd generation CL came out in 2001... with the 2003 models seeing a slight face-lift, and the addition of the manual tranny option.
Honda keeps a pattern... usually... every 4 years they unveil a new body style... and after 2 years running, give the model a face-lift.
Don't forget that the new TSX will be coming soon! It's basically a Euro Accord with acura badges, and it's gonna be sweet! I figured I should mention this since the Accord and CL are brothers in arms, and now their getting a new sibling.
Honda will redesign the TL for the 2004 Model Year, following its 5 year cycle. It will be introduced in the fall of 2003. The CL may be redesigned with it (or possible a year or so later), or it may get axed. Sales have been slumping.
If you want opinions and rumors on what the next TL might be like, go to the news and rumors forum: https://www.honda-acura.net/forums/f...php?forumid=27
There are a couple very long threads on the next TL with loads of information...do a simple search
Just a little snippit of information I heard regarding the next TL:
Rumor has it over in Japan, the next Honda Inspire (aka Acura TL) will have a Honda version of GM's 'displacement on demand.' If you've never heard of it before, it goes something like this:
The standard 6-cyl engine operates normally under any sort of acceleration. However, once at a cruising speed, half of the engine bay shuts down, leaving 3 functioning cylinders. This technology was once used on a few Cadillacs back in the 70's, and is currently being used on the Mercedes S600. (which has a V12)
Now I'm sure it will be engineered in normal Honda fashion (i.e. flawless). Obviously, the changeover from 3 to 6 cylinders would have to be seamless.....BUT I seriously wonder how 3 cylinders would generate enough steam to keep a 3400 lbs. car plowing along at 80 or 90 mph. Perhaps it is only meant for slower speeds...(?) Either way, it would do wonders for fuel economy.
If you want the link to the article, perhaps I can dig it up again....What do you guys think? Sound reasonable?
on www.vtec.net calendar it show that the CL might be cancel in 2005 and the TL in Fall of 2003 might be fully redesign with a 3.4L V6 280HP 6 speed manual transmission......AWD!!!!!!!!
