sixth generation clock and odometer.
Old Jan 27, 2009 | 04:38 AM
Default sixth generation clock and odometer.
do they light up? because mine don't
Old Jan 27, 2009 | 05:04 AM
losiglow's Avatar
losiglow
Clock = Always illuminated with the ignition is on. (kind of stupid really, light burns out faster that way)
Odometer = Illuminated when lights are on.
Old Jan 27, 2009 | 05:58 AM
so basically i need to replace the lights.
Old Jan 27, 2009 | 01:03 PM
losiglow's Avatar
losiglow
Yuppers. Unless you don't have any dash lights as well in which case I'd check the fuse. I'm assuming you have dash lights since you didn't mention them being out as well. The clock light is notorious for burning out though so it doesn't come as a big suprise.
Old Jan 28, 2009 | 05:56 AM
yeh, they gauges light up.
Old Jan 28, 2009 | 06:52 AM
losiglow's Avatar
losiglow
Sounds like just the odometer and clock light then. The clock light is easy to replace. If I remember, it's just two screws at the bottom of the ac/stereo panel to remove it, then you can replace the light. I've never taken the guage cluster apart but I'd imagine there's a backlight for the odometer.
Edit:
According to this it looks like you might be able to remove just the clock portion rather than the whole panel.
The guage cluster is another story though. It looks like you'll have to further disassemble it once you get it out to get to the odometer light.
Old Feb 1, 2009 | 10:24 AM
yeh, i've taken the clock out easily before when i was installing my hu i think. i'll have to dick around with the gauges. thanks.
Old Feb 2, 2009 | 07:58 PM
gottaBfast's Avatar
gottaBfast
If you can just replace the bulb in the clock, please PM me. I thought you had to replace the whole unit, otherwise i would have fixed mine by now
