Honda Accord 94-97: Changing Manual Tranny Fluid
~Items/supplies needed~
Shop towels(rags will do)
1/2" drive ratchet
3/8" drive ratchet(you can use a 1/2"-3/8" adapter too)
floor jack
drain pan
3 quarts of Honda manual tranny fluid(kinda costly)
or
3 quarts of your favorite Synthetic blend 10w30 motor oil
Lug wrench
Fluid pump(two different sizes, get one that fits a quart)
Aight now that you have all the vitals, let's get busy
**Make sure your tranny is warm before starting this procedure**
1.) Break the lugnuts on the front passenger side wheel, don't loosen them alot, just get em going.
2.) Jack the car up to remove that wheel
3.) Once you remove the wheel, you will see two plugs, one above the other, that have a square opening. The top one, the fill plug, is 3/8" while the bottom one, the drain plug, is 1/2". Remove the top plug first. Be prepared to exert yourself, it may be in there pretty good. The best way to remove these plugs would be to use a breaker bar, it is longer than a rachet and will give you more leverage when trying to "break" the plug.
4.) Once you've got that plug removed, get your drain pan and some shop towels and remove the lower plug, allowing the fluid to drain into the pan.
5.) After all the fluid is out, put the drain plug back in and tighten to manufacturer specs(don't ask me:dunno
*I just tightend up so its snug, then tapped it a few times w/the hammer just to be safe*
6.) Get ur pump and place the hose into the small opening where the fill plug goes, push it into the hole about a 1/2" or so, then open up a bottle of tranny fluid(or oil if you so choose) and screw the pump onto it and begin pumping with the bottle upside down, you will be able to get most of the fluid out if you pump upside down, pumping right side up will only allow you to pump maybe 1/5th of the contents. You want to add 2.5 quarts of fluid to the tranny.
7.) When you have filled the tranny w/2.5 quarts, have the fill plug in hand before taking out the hose of the pump cause some fluid will start to come out, remove the hose and quickly put the fill plug back in and tighten, giving it 3 firm taps w/the hammer to be safe(or better yet, torque to manufacturers specs).
8.) Re install your wheel, let the jack down, torque your lugnuts and you're ready to go, almost
9.) After doing this, I got in the car and w/o starting it up, I went through the gears about two or three times to work the fluid throughout the tranny, then started up the car and let it idle for a minute or two, then with the car running, went through the gears again.
That's all there is to it, it is an easy project given you have the right tools and do things in the order they need to be done to avoid having problems like I did. I did manage to get my problems taken care of and accomplished this w/o any further complications. Have fun!
1/2" drive ratchet
floor jack
drain pan
or
Lug wrench
*I just tightend up so its snug, then tapped it a few times w/the hammer just to be safe*6.) Get ur pump and place the hose into the small opening where the fill plug goes, push it into the hole about a 1/2" or so, then open up a bottle of tranny fluid(or oil if you so choose) and screw the pump onto it and begin pumping with the bottle upside down, you will be able to get most of the fluid out if you pump upside down, pumping right side up will only allow you to pump maybe 1/5th of the contents. You want to add 2.5 quarts of fluid to the tranny.
you should go ahead and post the problems you had before your fluid change(if u call it that with a teaspoon of fluid that came out of ur tranny), and how it basically fixed all your tranny problems. People might have these same problems but not know it might be their tranny fluid.
Dave
Dave
Dave
Dave
h:
All I can say is that manual transmissions rule!:thumbup:
Had you been half as neglectful with an automatic transmission...can you say $2k?
I don't think I'll ever buy a daily driver that's not manual transmission. Maybe if it's a leased weekend car (if I ever get to that point in life). But never an automatic in a car I know I'm gonna dog out on the highway or just running errands around town. Maintenance costs on the important stuff--transmission--is soooooo much more sensible. Even if you're a bad shifter and burn out your clutch, you can get a shadetree mechanic to put one in for like $300. Much better than someone asking you for $3000 to rebuild a 4-spd, Japanese-engineered transmission.
Originally posted by TypeSH
are u supposed to jack the car up so it is level before doing this? ie setting them on 4 jackstands of equal height?
Originally posted by cvc2k
nevermind... fill thru dipstick hole apparently.
Anyway...good u found it. Autotranny fluid is easier to change than oil, there's no excuse people shouldnt do their own.
Dave
yeh..that hunched me too.....it didnt feel right filling it through that hole. I dont know about civics, but on accords, the dipstick is almost at the "bottom" level of the car. And the space to work with is very compact, so you need a LOOOOOOONG funnel to fill it. Weird!
Dave
Dave
honestly i never new this could be done, or even heard of it.....
but i watched one of my coworkers do it on one of the hondas, not sure which model..... i walked in and the car was on the lift, he had already drained the so called tranny fluid.... i walked in late but when i did he put 10w 30 oil in there.... i have only done automatic tranny fluids and i thought you would put it in from the top but he was putting it from the bottom.....
