Saved myself ~$1200 this weekend on a Heater Core...
Old Jan 3, 2009 | 04:45 PM
Homestar's Avatar
Homestar
Default Saved myself ~$1200 this weekend on a Heater Core...
Well...
The shops told me that my Heater Core was clogged (98 Accord V6 sedan), and they were correct. However, instead of replacing it I took off the hoses that connect to the core at the firewall and attached equal diameter vinyl hoses. I then flushed the core with CLR several times, followed by hot water several times until there were no more sooty brown deposits coming out.
I drained the system prior to all of this- and also removed the radiator and soaked it in CLR overnight just in case. I also replaced the upper/ lower radiator hoses and the thermostat (the old one was working fine, but since I was already there...).
I now have heat in my car again for the first time in 20 months- and I'm only out a fraction of the cost to replace the core entirely. I feel that I did it right also, I took my time and did a thorough job. I don't feel that I cut any corners.
Hope I'm not posting old news, but I didn't find much on this by searching the forums and hope this will save someone else aggravation as I heard from the dealer that the 6th gen accords have this problem (they've done 10 or more in the last year.
Old Jan 7, 2009 | 06:18 AM
LodiHondaTech's Avatar
LodiHondaTech
Default Heater Core Flushout
Where did you get CLR? I'm having this same problem,and already replaced upper and lower hoses,radiator is 1 year old,heater control valve is in good working condition,new thermostat,new timing belt and water pump,as there was poor flow.Still nearly no heat!
Old Jan 7, 2009 | 08:24 PM
Driver's Avatar
Driver
slow lane cruiser
You should find CLR-calcium, lime, and rust remover at wal-mart or k-mart. Maaaaybee in an auto parts store, but I would check in the household cleaning products section of wal-mart or K-mart. CLR isn't too hard to find.
Not trying to knock the original poster, I've never tried this so it may be the miracle fix, but I'm just a little wary of trying stuff like this. But I am anal about my cars. If this works good with no negative side effects then I'd have to say:goodjob: Good Job Sir.
