HID System, Whatz the best?
Old Dec 21, 2002 | 12:57 PM
maddtekk's Avatar
maddtekk
Default HID System, Whatz the best?
Well, the title said it all. Has anyone heard what is the best HID system to install? Price Range? What voltage burns purple and blue? Or any information would be great. Thanks ALL!
Old Dec 21, 2002 | 01:26 PM
gregz93integra's Avatar
gregz93integra
Banned
APC HID's cost like $25.00 and there 100/80 watts. equivilant to 130 regular watts. there illegial but, who the **** cares anyways except some loser cop with nothing better to do. also, its said they can damage your car, but I don't what they mean by that, perhaps melt the headlight housing?
anyways...there a **** of alot brighter and better than halogens.
Old Dec 22, 2002 | 06:50 PM
THEOLDMAN's Avatar
THEOLDMAN
Checking it twice
Real HID's will run you anywhere from $400 on up. True HID's require ballasts to operate and are not plug in lights. The light output is measured in degrees Kelvin, the higher the temperature the more you get into ultraviolet range. If you get much above 5500* Kelvin you may actually loose some light as the road and other surfaces absorb the light. Also if you are seriously thinking about HID's you have to realize that the capsule is longer than the standard H1 capsule and that the focal point changes. The light no longer hits the reflector where it is designed to focus the beam. You will probably get a lot of people flashing their brights at you because you will be blinding them.
Old Dec 27, 2002 | 07:04 PM
taylormadem5's Avatar
taylormadem5
Thats funny about the focal point changing with TRUE HID'S, cause my best friend already gets people flashing there lights at him cause his lights are so bright. A true HID conversion is really a great setup, Phillips makes a great system. But its not cheap. OHH and those blue "white lights" are cheap, the dont last long, and if you touch the bulb with your bare finger..they will burn out extremely fast. It also looks gay IMO.
Old Dec 31, 2002 | 07:33 PM
this kit came from www.xenondepot.com . it has phillips ballasts with orsam bumbs. it was $475 shipped.
Old Jan 14, 2003 | 09:29 AM
mikEy type-S's Avatar
mikEy type-S
hahaha hey that's my car...what's up eklypse39!:thumbup:
Old Jan 14, 2003 | 10:37 AM
BonzoAPD's Avatar
BonzoAPD
true HID's can be plug in kits, but they need the ballast.
Old Jan 18, 2003 | 12:54 PM
SKYDC5's Avatar
SKYDC5
Go with the Xenondepot kit or the 5000K kit from McCulloch.
Old Jan 22, 2003 | 06:52 PM
Sheet One's Avatar
Sheet One
is it possible to take the HID system from a TL and put it in an RSX?
Old Jan 22, 2003 | 07:05 PM
mikEy type-S
i don't think it's the same bulb size...not sure though
