right pass window regulator
I'm having problems with my right window on my 99 accord 2 door. Was told the window regulator is the problem. I'm not too mechanically inclined but it this a fairly job I can do myself to save a few bucks? I couldn't find instructions on the board so If someone has that, it would be appreciated.
It's pretty easy, I've had to do a few on my 5th gen accord. Just find out how to get the interior door panel off (usually it's a few screws and some push tabs) and there are a few bolts holding the motor and regulator to the door, and a couple holding the regulator to the window. then when you get the other off, just install the new one.
I did this on my 2000 sedan. It isnt that hard at all...
The worst part was getting the regulator off of the glass and wrigling it out of the door. Pay particular attention to the orientation of the regulator as you re-install... that can be a little tricky and if you do it wrong, nothing will line up and you will have to wrigle it out again.
The whole job took me about an hour and a half - including a trip to the dealer to buy the regulator.
Hope this helps!
Geo
Hope this helps!
Geo
