This Autopage Alarm any good?
I was thinking about getting this alarm, what do you guys think about it?
Autopage RS-650 Alarm with Remote Start
Two, 4 button High Frequency Remote Transmitters
Window mount extended range helical transceiver antenna module
Remote car starter with 5 on-board relays and all the features of the RS-650
66 Bit Random Code Hopping
Code Learning / Anti-scan Receiver
Back-up Memory System
Dedicated Remote Panic and Car Locator
Dual stage shock sensor
Pre-warning indicator
Passive Arming By-pass from Remote
Parking Light Flash Dual Polarity (relay on-board)
2nd Channel Auxiliary Output
Plug-in Push type Valet/Override Switch
Plug-in Super Bright LED
Starter Disable Output with Relay & Socket (included)
Dome Light Illuminated Entry
1 Positive, 4 Negative Inputs
Error By-pass Reporting
120 db Electronic siren
Horn Honk Output
Ground When Armed Output
Dual Polarity (+/-) Door Lock Outputs
Drivers Priority 2 Step Unlock
All Programmable Features are Programmed via the Remote Transmitter
5 On Board Relays
Ignition 1
Ignition 2
Starter
Accessory
Parking Light
3rd Ignition Output
Ground When Start Output
Diesel Fuel Compatible
Hood Safety Pin Switch Input
Selectable Voltage / RPM Start Sensing / Timer Start
Timer Start Control (.6 seconds - 4 seconds)
Temporary Stop Feature
Factory Security Disarm & Rearm outputs
Programmable 3 Hour / 24 Hour Timer Start
Sensor Control Output During Start
OEM Alarm Output
Selectable Run Timer
Ignition Control Lock By-pass During Remote Start
Chirp Delete
Manual / Passive Arming
Passive Arming Door Locks
Ignition Control Door Locks
Automatic Re-arm
Single/Double Pulse Unlock
Pathway Illumination
Voltage Sense/RPM Sense/Timer Start
5,10,20,30 Minute Run Timer
Gasoline/Diesel Engine type
Lock-Unlock Output Timing (.9-3 sec.)
Factory Disarm/Rearm
Horn Honk Output
5 On Board Relays
Ignition 1
Ignition 2
Starter
Accessory
Parking Light
3rd Ignition Output
OEM Alarm Output
Chirp Delete
Automatic Re-arm
