main relay question
Old Oct 28, 2008 | 07:27 PM
bigwavedave33's Avatar
bigwavedave33
Default main relay question
Group,
I have a relay labeled rz-0088 that is used in the 90-97 accord with 2.2 4cyl engine. I have a repair manual and have searched the internet as well. They both refer to terminal 4. I have 1, 2, 3, 5, 6, 7, and 8?!?!? So that makes it a biyatch to test. Can someone give me some insight?
TIA,
Dave
Old Oct 31, 2008 | 02:02 PM
tommytomtom17's Avatar
tommytomtom17
Honda Driver
What are you trying to test? The number four terminal is not used on the relay.
File Type: jpg
Old Nov 3, 2008 | 05:54 AM
bigwavedave33
Thanks for the reply. The book I had shows terminal #4 being tested??? That is the correct one I needed. I had found the info on another board before you posted, but that is good info!
Old Nov 3, 2008 | 01:39 PM
tommytomtom17
Honda Driver
Is it not starting at certain times of the day? If so try resolder the relay
