Replacing TPS on 98 accord
Old Oct 27, 2008 | 07:26 AM
1998accordlx's Avatar
1998accordlx
VTEC INSIDE
Default Replacing TPS on 98 accord
Hi guys my accord seems to stall sometimes when at a complete stop. It only occurs one out of ten times....the rpm dropes to 600 and the car starts shaking...could that be the TPS sensor if yes i would like to replace it and i was wondering if it was something that i could do myself....is there any sort of adjustment to the sensonr????
Old Oct 28, 2008 | 05:27 PM
A-series's Avatar
A-series
v-card member alpha
Normally easy, but I'm not sure that's the problem. I4/V6, AT/MT?
Old Oct 29, 2008 | 12:40 AM
mrbkkt1's Avatar
mrbkkt1
Aiea, HI
ballpark, i would say yes, something similar happened to my accord v6, although it's a 00.
500 bucks to replace, but the part is only 120 I think, I was just super lazy.
it's fairly easy to access in the V6 though.
Old Oct 29, 2008 | 03:32 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
I have not played with an Accords TPS, if it's anything like a Civic's, it's probably on the TB. It will also most probably require an adjustment. Before you take the TPS off, take a reading with a multi meter on what voltage it sees with the TB completely closed. Write that down. Take a reading with the TB wide open, and write that down. When you swap the TPS, realign it so it sees those settings. That is how you do it on a Civic, probably the same on the Accord.
For Civic's the readings are .5 volts with the TB closed, and 5.0 volts with the TB wide open.
Project EVA - The Track Package
Project EVA
