acid smell from underneath the car
Old Dec 9, 2002 | 08:04 PM
shimsho's Avatar
shimsho
Default acid smell from underneath the car
I have 02 RSX, 25000 km, a smell like rotten eggs is coming
from underneath the car when I stop, was told that it might
be faulty catalic converter,
Has anyone experienced similar problem?
Old Dec 10, 2002 | 04:08 AM
THEOLDMAN's Avatar
THEOLDMAN
Checking it twice
Are you sure it's not coming from the exhaust pipe. The rotten egg smell (hydrogen sulfide) is a by product of the catalytic converter working on the exhaust gases. you may have a leak behind the cat if it is coming out from under the car. Have you installed a cat-back system, if so check for proper fit at the connection to the cat, and at the axle back section.
Old Dec 10, 2002 | 02:56 PM
RSXoholic's Avatar
RSXoholic
the anti-rice
yeah you usually get that smell when breaking in the engine. i did for a while but it went away. and it looks like youve well broken yours in (assuming you use the full rpm range regularly). check the bolts under there and if it doesnt go away bring it in and ask acura.
Old Dec 11, 2002 | 04:34 AM
shimsho's Avatar
shimsho
Yes, it seems like I might have a faulty cat. convertor, It should be covered by waranty ???
Old Dec 11, 2002 | 08:37 AM
RSXoholic's Avatar
RSXoholic
the anti-rice
if your car is stock and the cat is bad yes it should be. otherwise you have to make sure they cant prove your mods caused the damage.
Old Dec 27, 2002 | 10:59 AM
advan_typ3-12's Avatar
advan_typ3-12
ive been looking into rsxs recently and on like review forums, ive read the '02 rsx has some computer fuel management problem. The guy said it fed the engine too much gas, but he got it fixed at the dealer. He also mentioned that roten egg smell, i dunno if its that, just tryin to help
Old Dec 28, 2002 | 05:51 PM
RSXoholic's Avatar
RSXoholic
the anti-rice
thats not really a problem. the car just naturally runs rich.
