2 way or 3 way?
Old Dec 9, 2002 | 10:00 AM
smakdown's Avatar
smakdown
Default 2 way or 3 way?
Getting some infinity 6x9. Will two way be sufficient or will three way sound much better? Where I am ordering from, the 3 ways are only $10 more.
Old Dec 9, 2002 | 10:24 AM
SiClone's Avatar
SiClone
X-Moder8er
3 ways will have a bit more tweeter response. For $10 more, why not.....
Old Dec 9, 2002 | 06:15 PM
Bl@ck's Avatar
Bl@ck
Sinner
3 ways sound better with an amp.... 2 ways sound better when you're running directly off the hu
Old Dec 9, 2002 | 08:15 PM
ziggyziggy's Avatar
ziggyziggy
i am asian
why is that? is it because two ways tend to have more bass than 3 ways?
Old Dec 9, 2002 | 09:27 PM
Deagle's Avatar
Deagle
Nüb
I've heard that good 3 way speakers are harder to make, so if you're in the same price range, the 2 way speakers will perform much better. For good 3 ways you should have to pay a lot more money. Otherwise, what would be the point of getting 2 ways when 3 ways cover the same or more range, better? That's just what I've read.
Old Dec 9, 2002 | 09:33 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
Default Re: 2 way or 3 way?
I think you'd be better off paying the xtra $10 and getting the
3 ways. A two way, you only get woofer and a combination mid/tweeter. A three way, you get woofer, dedicated mid and dedicated tweeter. I would recommend the 3 ways for the same reason I would recommend components over coax's, better sound due to each component of the speaker(s) playing only a specified freq range.
Old Dec 10, 2002 | 01:32 PM
how bout 4-ways?
Old Dec 10, 2002 | 07:52 PM
steveng's Avatar
steveng
3 way is only as good as installation. if you don't plan to get them professionally intalled and setup, then just go with 2 way
Old Dec 10, 2002 | 08:42 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
what are you talking about? Why would you need to get some 3way 6x9's professionally installed and "setup" Please explain.
Old Dec 10, 2002 | 10:53 PM
steveng's Avatar
steveng
before i start to explain i get to make something clear first so i don't feel like a dumb ***.. the 3 way i meant has a pair of tweeters, a pair mid and a pair of woofers.
in most cases you have to build a kick panel for the woofers if mid's going into the door and tweets in the dash or whatever.
you want the kick panel to be professionally done so that the sound stage is at the optimum level. make sense?
