reverse gauges
does anybody know how to install reverse gauges i have tried and broke the gas gauge. and i just had my friend try and he broke the temp gauge... cant get the gauge to go over the needle..... help please... its on a 97 accord.
if you broke the needles you need a new gauge cluster
normally to install new faces slide part of it over the needle then to get it around the circle base part of the needle bend the new face just a little and pull it to the side while doing so it should slip under the rest of the needle.
