Having Trouble getting the door apart. Please Help!!
I just got a 2003 Accord yesterday and the speakers sound like crap. I want to change them out but I don't want to break anything in the door sill. How are you supposed to get the door apart to get to the speakers. Thanks guys for all of you help.
Looks like your door panel has snap clips like mine. From the diagram, appears there's a screw in the handle assembly and one in the door handle. If like mine, the door handle is a torx screw. Think T-40. The rest snap in, usually a flat screw driver with a rag (to protect your paint) will do the job for prying off the door after the screws are removed. I prefer a set of door trim pry bar set. Picked up a set a while back cheap for $6 at harbor freight tools. You want to get as close to the clip as you can with the end of whatever tool you decide so you don't break the plastic door lining.
The pictures I attached are for a 2003 4dr LX but should be about the same if you have a 2DR.
