Coolant Drain Plug
Old Aug 25, 2008 | 10:28 AM
ulnv4ever's Avatar
ulnv4ever
Default Coolant Drain Plug
hello,
I have a 2007 Accord, 4cyclinder, auto, 4 door. I am trying to drain the coolant out of the radiator. Do you know where the drain plug is on the radiator? thank you for the help...
Old Aug 25, 2008 | 01:53 PM
JimBlake's Avatar
JimBlake
Looks like its just to the right of center, in the lower tank of the radiator.
Old Aug 25, 2008 | 03:17 PM
Line7's Avatar
Line7
Platinum Member
If you still cant find it, yank the lower radiator hose.
Old Aug 25, 2008 | 03:30 PM
ulnv4ever's Avatar
ulnv4ever
thanks. that's part #2 right?
Old Aug 27, 2008 | 04:41 PM
ulnv4ever's Avatar
ulnv4ever
I am new at the coolant business, so i got few questions:
1. do i drain the coolant when it's hot? or better when it's cold?
2. is there air bleed screw I need to open on the radiator?
3. instruction on the bottle says I need to turn on the heat, is the the heater in the car?
thanks for the help.
Old Aug 28, 2008 | 04:58 AM
Line7's Avatar
Line7
Platinum Member
First off, why are you doing this?
But to answer your questions:
Its obviously better to drain it when the car is not hot, so you dont burn yourself. Once you fill with new coolant you have to bleed the system of air. With the radiator cap off and engine running, top off the radiator. You can turn the heater on, its not that integral of a step. It would speed the proceedure to give your throttle cable a tug once every few seconds. You want to have the coolant in the radiator up to a boil. When it starts boiling out to add more to keep it topped off. If you have a air-bleed screw, open it in the middle of this proceedure. You want a continuous stream of water to come from the bleed valve, if its squirting, you still have air in there. Proceedure should take 7-10 mins.
