Radiator removed, trans lines
Hi all,
I removed my radiator but now Im having trouble removing the transmission line fitting(mounts up to the radiator) from the hose. The radiator I bought came with fittings installed already.
For some reason the hoses are stuck on the metal hoses.
Does anyone have any tricks on how to get them out of the hose?
Thanks for your help,
Norris
Norris
they will come off easy with pliers.. get new hoses from honda as depending on how old the hoses are once disturbed they can leak and is a pain to replace once in the car! you can use bulk hose but they are either going to be too loose ot too tight!
