h23?
Old Nov 16, 2002 | 10:35 AM
xbladr's Avatar
xbladr
Default h23?
I was wondering if it was worth it to go for a h23 into my 96 honda civic dx? how much would an h23 cost me and how much for install probrably? Also i heard the h22 brakes axles which is the reason i am thinkin about the h23 i dont need my car to be rediculously fast just mid to low 14's would suffice for me. Please let me know if i can pull it off and what not thanks alot
Old Nov 17, 2002 | 12:22 PM
silentrage's Avatar
silentrage
the H23 is great. The H23 would be the ideal engine to go with if your planning on adding a turbo. i think the H23 runs about 2000 used and the H22 runs about 2700 used depending on where you get it from. in a light civic the H22 or H23 would definatley get you where you wanna be. high 14's. and with a few modifications you'l be in the low to mid 14 range. thats just my estimates tho. the swap is ridiculously expensive but it is somehwat costly. i say go for the H23.
Old Nov 17, 2002 | 12:32 PM
96AccLX's Avatar
96AccLX
Professional
Old Nov 19, 2002 | 05:50 AM
v4lu3s's Avatar
v4lu3s
its the same install as an h22 and its jsut as likely to break axles as well. the torque figures for h23a1's and h22a's are about the same anyway.
Old Nov 19, 2002 | 06:43 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Just go with the H22A-R, the engine costs a bit more but has more hp and torque.
Old Nov 19, 2002 | 12:39 PM
redheat86's Avatar
redheat86
DoriTen y0
for the times your gona run with an h22a..asnd the price your going to spend..you might as well get a b18c-r..the rpice will be nearly the same and youll run the same times if not faster..
Old Nov 19, 2002 | 07:01 PM
xbladr's Avatar
xbladr
the h22a is about 2200 and the b18c is like 3200 big price difference not even close so thats why im not doing b18c
Old Nov 20, 2002 | 04:17 AM
v4lu3s's Avatar
v4lu3s
an h22a should put the car in mid to low 13s. and you can get it for a little less.
osakajdmmotors.com has em for like $1850 plus shipping.
Old Nov 20, 2002 | 12:17 PM
redheat86's Avatar
redheat86
DoriTen y0
yeah motor to motor cost is differnt.. he still has to get 4-600 bolt in kit.. new axles... lude/accord cable shifter... and also your gona wana spend the extra moneya nd get the lsd cause its prolly gona be even more prone to breaking axles without it....the main reason for people braking axles is usually having it way to low and the axles binding... now with that all said.. ill bet anyhting youll be lucky to get into the 13's with a lude motor. has it been done, yes.... its not very common though..
Old Nov 21, 2002 | 08:36 AM
xbladr's Avatar
xbladr
in a 2200 lb dx 13's shouldnt be too difficult i dont think
