FS: 1992 Acura Integra 3dr....CLEAN $4000
Old Jun 20, 2008 | 10:27 AM
capsule's Avatar
capsule
Default FS: 1992 Acura Integra 3dr....CLEAN $4000
1992 Acura Integra LS Hatch....$4000..............Priced lowered to Sell!!!!!!!!!!
Located East of Phoenix, AZ..........In Mesa, AZ
LS Model,
Power Moonroof
Power Windows
Power Mirrors
Fog Lights
Has Basic Pioner CD Deck w/ 2 Front Speakers.
All Interior Power functions work!!!!
Security:
Viper Alarm, w/ alarm sensors, 2nd Shock Sensor, + Tilt Sensor, Keyless Enrty. Great alarm. Works Perfect.
Clean Title...Clean Carfax....Vin # on Request.
Money Talks BS Walks..........No Trades, No Payment Plans. Cash Takes the Car...Title in hand.
Call Scotty at 480.226.0120
Performance:
-B18a1 Runs a good as New. No leaks, No smoke, Runs perfect.
-New rotor, cap, spark plugs, wires, valve cover and gaskets.
-Water pump and all belts replaced 1 year ago.
-Upper and lower radiator hoses replaced. Car flushed and switched to Honda’s new blue coolant.
-Innovative Mounts “polyurethane mounts”…..All 4 replaced. - Almost New 6 months on car.
-4-2-1 Stainless Header - Almost New 6 months on car.
-Iceman Intake - Almost New 6 months on car.
-OEM Cat – Still perfect.
-Full Stainless cat-back exhaust. - Almost New 6 months on car
Interior:
-B&M Shirt shifter, w/ energy suspension shifter bushings
-F1 Spec fiberglass racing seats. - Almost New 6 months on car
Seats have Weapon R Mounting brackets, Drivers Seat has Sparco slider.
-Racing 4 point harnesses.
-2005 civic space saver spare tire.
-90% of all interior sound deadening removed.
-Interior BLACK. All extra weight removed….It’s Dash and Door panels.
IE: A/C Lines, condenser, Heater core, Anything in regards to heater or A/C Completely removed.
Suspension & Brakes:
-Brand new OEM Calipers..All Around..NEW
-Rotora slotted Rotors…All around. NEW
-Rear Trailing arm Bushings replaced with Polyurethane race mounts. PRothane..NEW
-Front and Rear Sway bar Energy suspension poly mounts. ..NEW
-Front Sway bar end links energy suspension..NEW
-Tokico Blue Shocks….less than 5k
-Tein S-Tech Springs…less than 5k
-Front lower ball joints NEW. ..NEW
-Front upper control arms and ball joints NEW
-Front Outer Tie rod ends NEW
-Front CV Axles, NEW
Exterior:
-Aftermarket Amber corners and Turn signals. ..NEW
-OEM Mud Flaps All 4
-Door handle key holes are Fakes.
-Car has keyless entry with Alarm. Tilt sensors, shocks sensors, glass break sensors.
-Power windows.
-Moonroof….Still works perfect.
-Body is very clean for 92. Has OEM paint that still shines. Only the hatch is painted black.
-02-03 Civic Si Wheels w/ Dunlop Tires. Half life left.
Bad:
Cracked windshield……No A/C or Heater.
Good:
SCCA Racing Ready…..Needs some changes to be NASA racing ready.
I do not want to sell. But my financial situation is forcing me. As you can see I never planed to sell the car. Everything is Brand new or 6 months old. Car runs perfect. And very strong and fast.
