my hybrid seems to hesitates on acceleration..
I have a 94 b18b in a 94 civic ex coupe. Just swapped it in about 2 weeks ago and during acceleration you can feel a slight hesitation then power will kick in. It has a new distributor, cap, rotor and plugs.. I've even pulled out in traffic a couple of times and have the car not even want to move for a split second then it will resume as normal. Any ideas?
My 89 Si with a 92 B18A1 does the same thing. But It did that when it was in the teg also? I bought a fuel presure gauge and it sits at 35 psi when idle. Timing is correct also. If anyone knows what the problem is, please reply. I would like to know as well........
it should suffice just fine..fuel pumps do go out with stress.. depending on if you had a fuel presure riser/regulator..it could have stressed the pump..age of it..or milage possibly... one of my old accords did this very same thing. i could never figure out what it was though.. have you chnaged your fuel filter recently?
the reason i say its fine is, an h22 swap me and my friend did..we left the factory dx fuel pump and the car ran fine and never had any problems.
I felt pretty stupid and bad about beating on her like that with that little of oil but I filled her back up and she runs like a champ again.
