95 Acura Integra DB8 GSR Green/Tan Mods $3800
1995 Acura Integra 4 door GS-R ( DB8 ) Dark Metallic Green paint ( 6 weeks old ) Clean car never wrecked. Some dings, no rust. Tan cloth interior ( clean ) 192,XXX miles Runs excellent. All power options work, this GS-R has everything except fog lights. Pulls HARD, no grinds on shifts. $3800 SALE!!!!
Recently Done:
Timing belt, water pump
Crank seal
cam seals
Valve cover, distributor, vtec solenoid etc. seals replaced
20k on clutch
Front and rear brakes @ 70%
Tires at 60% Yokohama Avid 195/55/15 on Clean fat fives
DC sports 4-1 Header
Random technology high flow cat
Skunk 2 exhaust w/silencer
Trans replaced @ 185k w/ low mile GSR trans. due to bad synchros.
Will also throw in stock complete header and cat w/ new o2 sensor.
The ABS light comes on every once in a while and they said it needed an ABS pump. I have one and will include it in the sale. The only other issue the car is having right now is a whining noise on deceleration. Only happens in 1st and 2nd below 10MPH. I was told that I need to replace the Speed sensor gear to fix that. Trans runs great no other noises, shifts perfectly at 8k. Need to sell. Making room.
Located near Andrews Air Force base, MD
Recently Done:
Crank seal
cam seals
20k on clutch
