aem bypass valve
Old Oct 28, 2002 | 02:49 PM
jordan88's Avatar
jordan88
Default aem bypass valve
hi, i am just wondering how does the aem bypass valve work? how does it shuts off when there is water injection?
thanks you!!
Old Oct 28, 2002 | 02:56 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
its a piece of foam that takes the place of a section of CAI. since the foam is hard it is easier for the engine to draw through the cone. if the cone fills with fluid though the pressure through the cone becomes tougher so the engine then draws through the foam instead.
crucial Si's Avatar
crucial Si
Banned
its a good way to loose the hp you gained from the intake.
Old Oct 28, 2002 | 03:08 PM
Fujiwara Takumi
It's my first day.
i kinda wonder about that.
its designed ok, i mean, that technology has proven itself in electrical circuit design, so i can see its application in fluid/thermal dynamics, but i always wonder.
if the foam breaks down, this would certainly become evident.
Old Oct 28, 2002 | 03:10 PM
jordan88's Avatar
jordan88
ok, so how does the bypass valve prevent from water injection? i see there is a spring inside, and some foam, but i just can't think of how it works.
thanks you.
Old Oct 28, 2002 | 03:29 PM
Tony96EX's Avatar
Tony96EX
the valve opens and draws air from within the engine bay. the water doesn't reach the valve.
Old Oct 28, 2002 | 03:58 PM
Fujiwara Takumi
It's my first day.
also the sudden drop in tube pressure would theoretically release the water. once its again easier to draw through the tube the bay valve would automatically close.
Old Oct 28, 2002 | 05:31 PM
crucial Si's Avatar
crucial Si
Banned
it kinda sucks that you pay an extra $50 on top of the w/e amount the aems cost..they make you cut it in half and add that for the power gain of 0 hp...so you end up paying around what $250+ to have something shiney in your bay...thats some weakshiit. shiit ive seen people put it on the iceman...now wtf is the point of that? you have a shortram/cai system..why bother?
Old Oct 28, 2002 | 09:06 PM
Outxider's Avatar
Outxider
X-Motoring
aem bypass valve = 3 weeks worth of premium gas for me. spend ur money elsewhere and have common sense and u will be kewl.
late
Old Oct 28, 2002 | 09:09 PM
Fujiwara Takumi
It's my first day.
Originally posted by Outxider
have common sense
late
truer words.
